Help me with L shaped vent please!
ok so im playing around with random designs so i can get better at designing and tuning enclosures... normally i try to stay away from L shaped ports but on this particular design... its just not possible... so my question is how does the 90 degree port bend affect port length and how do you go about measuring the bend? any info you guys can give me is much appreciated...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Measure the port length down the center of the port.
Pretty sure for port correction you add to the length. Use expos box calculator and see what the difference is in it.
Edited by n8ball2013
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
draw your port
measure down the center!!! say your port is 4 in wide, you will basically be adding 4 inches of length compared to the inside(shorter) wall, 2 inches on each length (cuz its 2 inches to get to the center)
if you put up a sketch with dimensions im sure someone could double check it for you
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
ok... so say the port is 4 inches wide... and is supposed to be 28 inches long... so then i would actually measure 32 inches?
Edited by Rogers
3 Kinetik Hc2000's
Dual 200amp alts.
ok... so then i would also have to readjust my volume too right? to compensate for the extra 4 inches?
3 Kinetik Hc2000's
Dual 200amp alts.
im guessing if youre saying 28 inches, you have something along the lines (arguments sake) of a 20 inch side (inside the L) with 8 inches along the back of the box.
which means the outside of the box would be something like 24.75 long (20+4+.75 for wood)
if thats the case, the center would actually be 22 (full length of inside+2 inches to get to center of the bend) and the other side would be 10 (again, 8+2)
so yes, 32.
if you were measuring the outside (of the inside of the port...) it would actually be 24x12, or 36. in this case you'd subtract 4, again because you're trying t center the measurement.
only pic i could find, ignore his little 45deg calc unless you're doing that too, but this should give you an idea
Edited by raytard
Team DC
ok... i got the measuring part understood now... ok so then from what im understanding... the port displacement wont change... we are just adding the 4 inches for sake of center measurements... right?
3 Kinetik Hc2000's
Dual 200amp alts.
if you are adding on to your port your vent is longer it will change the displacement of the vent.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
draw your port
Skip the last part of that - it threw you off. He was just saying if you measure the outside of the port, it will be different than the inside of the port.
That is why you measure down the center.
EDIT - oops - I see you have another thread and are on track.
Edited by huh
  • Who's Online   1 Member, 0 Anonymous, 1032 Guests (See full list)
