Rogers Posted February 8, 2010 Report Share Posted February 8, 2010 ok so im playing around with random designs so i can get better at designing and tuning enclosures... normally i try to stay away from L shaped ports but on this particular design... its just not possible... so my question is how does the 90 degree port bend affect port length and how do you go about measuring the bend? any info you guys can give me is much appreciated... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it? Link to comment Share on other sites More sharing options...
-Hobby- Posted February 8, 2010 Report Share Posted February 8, 2010 ok so im playing around with random designs so i can get better at designing and tuning enclosures... normally i try to stay away from L shaped ports but on this particular design... its just not possible... so my question is how does the 90 degree port bend affect port length and how do you go about measuring the bend? any info you guys can give me is much appreciated... Measure the port length down the center of the port. Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 8, 2010 Report Share Posted February 8, 2010 (edited) Pretty sure for port correction you add to the length. Use expos box calculator and see what the difference is in it. Edited February 8, 2010 by n8ball2013 Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
raytard Posted February 8, 2010 Report Share Posted February 8, 2010 draw your port measure down the center!!! say your port is 4 in wide, you will basically be adding 4 inches of length compared to the inside(shorter) wall, 2 inches on each length (cuz its 2 inches to get to the center) if you put up a sketch with dimensions im sure someone could double check it for you Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
Rogers Posted February 8, 2010 Author Report Share Posted February 8, 2010 (edited) ok... so say the port is 4 inches wide... and is supposed to be 28 inches long... so then i would actually measure 32 inches? Edited February 8, 2010 by Rogers Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it? Link to comment Share on other sites More sharing options...
Rogers Posted February 8, 2010 Author Report Share Posted February 8, 2010 ok... so then i would also have to readjust my volume too right? to compensate for the extra 4 inches? Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it? Link to comment Share on other sites More sharing options...
raytard Posted February 8, 2010 Report Share Posted February 8, 2010 (edited) im guessing if youre saying 28 inches, you have something along the lines (arguments sake) of a 20 inch side (inside the L) with 8 inches along the back of the box. which means the outside of the box would be something like 24.75 long (20+4+.75 for wood) if thats the case, the center would actually be 22 (full length of inside+2 inches to get to center of the bend) and the other side would be 10 (again, 8+2) so yes, 32. if you were measuring the outside (of the inside of the port...) it would actually be 24x12, or 36. in this case you'd subtract 4, again because you're trying t center the measurement. only pic i could find, ignore his little 45deg calc unless you're doing that too, but this should give you an idea Edited February 8, 2010 by raytard Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
Rogers Posted February 8, 2010 Author Report Share Posted February 8, 2010 ok... i got the measuring part understood now... ok so then from what im understanding... the port displacement wont change... we are just adding the 4 inches for sake of center measurements... right? Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it? Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 8, 2010 Report Share Posted February 8, 2010 if you are adding on to your port your vent is longer it will change the displacement of the vent. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
huh Posted February 9, 2010 Report Share Posted February 9, 2010 (edited) ok... i got the measuring part understood now... ok so then from what im understanding... the port displacement wont change... we are just adding the 4 inches for sake of center measurements... right? draw your portmeasure down the center!!! say your port is 4 in wide, you will basically be adding 4 inches of length compared to the inside(shorter) wall, 2 inches on each length (cuz its 2 inches to get to the center) Skip the last part of that - it threw you off. He was just saying if you measure the outside of the port, it will be different than the inside of the port. That is why you measure down the center. EDIT - oops - I see you have another thread and are on track. Edited February 9, 2010 by huh Quote Link to comment Share on other sites More sharing options...
