Well, I did purposely send my sub a clipped signal of 40hz to see exactly how a major clip sounded like. And the sub was moving no where as much as it does on an unclipped signal. So I was just assuming that it made it so the sub less than normal and that's why it couldn't get rid of the heat that well.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
hardcore competitors in spl actually use soft clipping to give them more power
thats why giant amps give ratings from 1% thd all the way up to 10% thd
since they only burp for 3 seconds its just about getting the most power u can
so the clipping isnt an issue because its very hard to get to 500+ degrees on a voicecoil in 3 seconds
i guarantee those with oscopes first burp on a clean signal and then they keep turning it up until they see either no more db gains or stresses start to show in the sub or amp... hence why spl above 170db is so much trial and error
im not sayin they use hella clipped signals, but a little bit actually helps so long as u know what ur doing
I thought my subs were clipping.
Till I put Dynamat Xtreme on the sheet metal behind my tail lights.
Suddenly I no longer hear that rattle.
awsome, thanks decaf, ill check out some songs from the carter to get familiar with bad clipping. it was more or less the sound that scared me, but i guess it was just the tuning of the EQ that did it.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
I was actually thinking of this the other day, because on some amps when I looked at rated power, it would give ratings at 1%, and like 4%, or 5%, 10% etc. I was actually thinking that people using amps for burping would get the THD up as much as possible to get the most power out of the amp, because just like you said..it's only 3 seconds.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
