Ben Building Posted February 13, 2010 Report Share Posted February 13, 2010 Ahumm, i wasnt really sure of any other box designs for an 18...that i like atleast any other ideas? Well, when the port shares one wall with the enclosure, it creates more drag as the air enters and leaves the rear-end of the port. You probably won't notice unless you have a meter or are putting a lot of power on the sub, but there is a difference. Maybe move the port over a few inches? Put a 45 (not 90) degree bend in the port? I have lots of ideas, but you have to figure out what your application needs. Quote Link to comment Share on other sites More sharing options...
NcHalfrican Posted February 13, 2010 Author Report Share Posted February 13, 2010 Would an aeroport be a viable option for this sub and setup(SAZ-1500D)? Quote Link to comment Share on other sites More sharing options...
NcHalfrican Posted February 13, 2010 Author Report Share Posted February 13, 2010 Was looking at this 6" aeroport kit... http://www.parts-express.com/pe/showdetl.c...tnumber=268-354 Quote Link to comment Share on other sites More sharing options...
Alexdb7 Posted February 13, 2010 Report Share Posted February 13, 2010 you need to make sure your port area is in the port area range, or your going to get port noise. Quote Custom Car Audio (815) 916 - 9194 www.midwestsplcustoms.com 2000 Tahoe | 22" GREED Celebrities Alpine CDA-117 Dual 0/1 Runs (3) 925 CA Group 31 In Back (4) 18" FI Audio Q's (W/ Extra Spider) (4) Hifonics BXi 2010D Hifonics ZXi 4410 4 RF P1653 6 1/2's Big 3 All Kicker/Knu Wiring Link to comment Share on other sites More sharing options...
BlurdvisionKustomz Posted February 13, 2010 Report Share Posted February 13, 2010 i dont know about 18's but the 12 is 27.1 cu ft per woofer so, you can always call scott and he can give you the driver displacement. Quote Link to comment Share on other sites More sharing options...
Tyan Posted February 13, 2010 Report Share Posted February 13, 2010 if u go with aeroports u will need to get three or atleast two 6" aeros .... Quote my VIDEOS Link to comment Share on other sites More sharing options...
NcHalfrican Posted February 13, 2010 Author Report Share Posted February 13, 2010 if u go with aeroports u will need to get three or atleast two 6" aeros .... Why would i need multiple aeroports? Quote Link to comment Share on other sites More sharing options...
Tyan Posted February 13, 2010 Report Share Posted February 13, 2010 Why would i need multiple aeroports? cause of the port area ....not needed as much as for slot ports but got to go safe for the box volume and btw. i have a Havoc Quote my VIDEOS Link to comment Share on other sites More sharing options...
NcHalfrican Posted February 13, 2010 Author Report Share Posted February 13, 2010 cause of the port area ....not needed as much as for slot ports but got to go safe for the box volumeand btw. i have a Havoc Ah, i knew that...i feel like an idiot now haha ya i know...subed a while back Thanks for the info dude! Quote Link to comment Share on other sites More sharing options...
bkolfo4 Posted February 13, 2010 Report Share Posted February 13, 2010 Nothing wrong with your design above, except the port needs to be longer to get the correct tuning. Changing the port from 10" long to 17" long still leaves you with 8.2 cuft and the correct tuning. I run all of my 18's in 6.5-7 cuft and they sound great. Driver displacement can be estimated at .25 cuft. That will be close enough. If you want to go with Aero ports, (2) 6" is plenty for a 18" Havoc. That is 56 sqin, which will work fine. Aero ports do not require as much port area as a slot port. Brian Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
