Rydaz1Bass Posted February 13, 2010 Report Posted February 13, 2010 Ok guys i recently bought an Audio pipe Platinum multi fuse holder and i just hooked it up and on the pachage it said it has two blue LED light indicaters to state that the fuses are good now my car sits around and i dont use it much.it uses a seperate ground to be turned on is there any way i can run a switch to the ground to turn the LED's on and off? because i dont want my car sitting around and the LED's over time to run the battery down and the reason why i am asking this is when the car is fully off the leds stay on all the time and i was wanting to run a switch to have them turned off so they wouldn't be on all of the time......... i was thinking about running the ground off of the led indicater to the ground of the switch that way i can flip the switch so the ground will loose contact to the frame of the car and i think tha would turn the lights off does that sound right??? please help me this is hard to get out right :01nocomment8so: VehicleCurrentlyOwned:2000Malibu \/MySystem\/ Ken-Wood HeadUnit Cars interior panels Custom blue Done by ME Pheonix Power block running both amps Stinger pro series four gauge wire flex material RimsBrand:Polo Interior lighting Blue neon bars under and around dash Capaciter:Pyle Dryver 1.7 farad digital meter read off new(INSTALLED) http://blog.sounddomain.com/photos/orion/april_21_07_004_2.jpg http://www.dcsoundlab.com/images/header.jpg
kx519 Posted February 13, 2010 Report Posted February 13, 2010 Ok guys i recently bought an Audio pipe Platinum multi fuse holder and i just hooked it up and on the pachage it said it has two blue LED light indicaters to state that the fuses are good now my car sits around and i dont use it much.it uses a seperate ground to be turned on is there any way i can run a switch to the ground to turn the LED's on and off? because i dont want my car sitting around and the LED's over time to run the battery down and the reason why i am asking this is when the car is fully off the leds stay on all the time and i was wanting to run a switch to have them turned off so they wouldn't be on all of the time......... i was thinking about running the ground off of the led indicater to the ground of the switch that way i can flip the switch so the ground will loose contact to the frame of the car and i think tha would turn the lights off does that sound right??? please help me this is hard to get out right :01nocomment8so: Just run the ground wire to the switch as if it was a hot(live) wire. Which, in this case it kind of is. 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
sphinxbccp Posted February 13, 2010 Report Posted February 13, 2010 i thought most of those have a voltage sensor so they shut off when not in use Build log: Click Feedback: http://www.stevemead...xbccp-feedback/ 03 Chevy Blazer - IPad Air 2 - ALPINE Head Unit - 4 DC XL 18s - 2 DC 3.5k - ALPINE TYPE R 5.25 COMP - 3 ALPINE TYPE R 6.5 COMPs - DC 175.4 - DC HO Alt - D3400 - 4 XP3000s - KNU 0ga - 60 SqFt Damp Pro Lots more...
