STEvil Posted February 14, 2010 Report Posted February 14, 2010 use fiberglass resin to fix it, cant hurt. Cut the holes for 15 and put a V shaped peice at the back of the large port.. might still work pretty good Careful on the low notes at the start in case its ported way high. If it is you could add an L shaped piece at the back of each chamber (leading into the port) to drop the frequency a bit. Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
