hifonics xx-colossus II ?'s
sic_fx
can i run a colossus II at 1 ohm mono? i just sold all 4 of my stroker 15's, they are goin in an extended cab s-10. i would like to do the colossus II, it fits the budget for this guy better than a goliath does, and really wants hifonics power.any info would be more than greatly appreciated so i can get this guy some amp prices and get this install moving.thanks
groundpounders-sig-2.jpg 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now!
they rate it at 1 ohm stereo (2x1600 rms@ 1ohm) i need 1 ohm mono. the 4 strokers are single 4 ohms. but if it will run at 1 ohm mono that is the amp i'll run.
Guest 90accordman
not with a colossus,  the only way youll get the 3200 is bridging the 2x 1600s
why not wire 2 to one channel at 2ohm and 2 to the other channel at 2ohm, youd get the same power as if you did it your way.
i think i found a digital diesigns z1 to use for this install. i told the guy i'm building this truck for about it and he seemed pretty stoked. now just to get him to give me the money to buy the bastard. i figure 4 15" strokers at 1 ohm on a z1 will get pretty fuc**ng loud. :^ :D :-*
Bench tested by Peter.T from Soundpressure.com (Sweden):
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
14,4 Volts:
4.6 ohms = 3042W
2.3 ohms = 4461W
1.15 ohms = 5358W
got that from ampguts, if it does 4100 at 12 volts i'll be happy. this guy wants to spend less than $1000 on an amp, and i can get him this amp for that price. it'll be nuts any way you look at it...4-stroker 15's, 4kw, ext. cab s-10, 18.5 cu.ft, tuned to 31hz. this truck will be loud.
p.s.-love the avatar :-*, that's a bad bit**.
Guest 90accordman
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
14,4 Volts:
4.6 ohms = 3042W
2.3 ohms = 4461W
1.15 ohms = 5358W
GL with the cu feet your trying to get, i believe manny has 8 cubes in his and it looks like there isnt much more room
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
