subs/sub up port back ;]
x2 this.
if your gonna stick with your stock electrical and the RF 500w amp, stay with an SSD. also, ditch the capacitors.
What year is your jeep?
It is a 94, looking at your vids I think you do too, or atleast something close ( I think).
If money isn't a big issue, do you think I should go with 2 15"s or one 18?
I like the roof flex btw. Looks a lot like mine. I havn't tried a soccer ball though lol.
x2 this.
K thanks for the tip I remember that when I get around to building the box for the FI's.
I do have to ask tho, if you are certain on the caps? if I lose them my lights damn-near cut off. with them on I only see my In-lights flickering. Not trying to be smart, just hesitant???
And I plan on getting a 350amp alternator. Do you know s 'Cheap' good battery or 2 I can add on?
you need an extra battery then you wire it like this
front batt---------------fuse---------------rear batt-------------fuse amp OORR
front batt----------------------REAR batt--------fuse--------amp OOOOOR
ALT--------FUSE-----BATT------------BATT-------FUSE-----AMP
really up to you stops dimming and helps you not torture the amp
i got 3 batteries but im not sure what you consider cheap, we can help you with a lot but you have to know how much you are willing to spend
Edited by Red-navi-916
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
My jeep's a 95.
2 15"s will have more cone area, so will essentially have potential to get louder then a single 18.
The roof flex is rediculous, but significantly less after I deadened the roof (which is good). Without the roof vibrating as much, my roof racks don't rattle anymore. Before they were like a giant swarm of jackhammer-toting killer bee's.
I would say you can keep the caps, they won't hurt too much. If you are going to have a 350amp alt, I don't see why you will need a battery besides the main one for starting. That is assuming you won't have rediculous amps. For instance, I'm running about 1200 watts to my sub with only a 240 amp alt and the regular starter battery. I get barely any voltage drop, even at idle. Sometimes the belt will slip if I'm idling and playing a really loud, droning bass line, but that doesn't happen often.
I'm guessing if you are planning to get a BL, you will have like a 1500w amp. With a BTL, you will need a bigger amp and you might want a battery or two, I don't know.
That's my opinion on it.
My Youtube Page. Check it out
The "SAV" - Sub-aural Assault Vehicle
Kenwood eXcelon KDC-X993
Image Dynamics CTX 6.5" Components
Q-logic 6.5" kick pods
CDT 6.5" CL-E6NEO Front door Midbass
Kicker ZX350.4
Knukonceptz SS Karma 4 channel 6m RCA
Fi Q 18" w/ brushed aluminum dust cap
7cu ft. ported box tuned to 28hz
Sundown SAZ-1000D
Iraggi 240 amp Amputator Alt
Big 3 in Monster 1/0awg
Second Skin Damplifier Lite on roof and front doors
What year is your jeep? I have an 18" Fi Q in my 95 GC. My rattle was pretty loud, and I determined it was the roof racks. I recently deadened the roof and that just about got rid of all of the roof rack rattle. Now it's my back hatch that's making a lot of noise. Get some sound deadener for that.
I would recommend the BL over the BTL for you simply because it'll be much more expensive in the long run to have a BTL, and a BL will probably get plenty loud for you.
If you want to check Vids of my sub in my car, check out my youtube page in my signature.
BTW can you send me a link to the alternator you got? the one Im looking at is kinda sketchy looking.
EDIT: now why did this pop up twice???
Edited by Michael314
Michael314 - please make your sig shorter
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
who sells a 350amp alternator? i bet that thing outputs like 50amps at idle.
DC Power alternators have an alternator that does 270amps max and 200 amps at idle (700 engine rpm i think)
edit: capacitors + stock electrical system + voltage drop = fried alternator sooner or later.
Edited by Kranny
What is the significant difference in BTL and BL? or are there a few
  • Who's Online   1 Member, 0 Anonymous, 447 Guests (See full list)
