988216855 Posted February 17, 2010 Report Posted February 17, 2010 Hi Guys. opinions or suggestions whether i should buy this amp at this price is it worth it?? for a power amp is it good?? any other suggestions on any other amps of 1000 watts rms? and does anyone one know the actual power that it can deliver. if you guys think it would be a good buy what would be some perfect subs for it?? http://cgi.ebay.com/Rockford-Fosgate-T1000...#ht_2081wt_1148
wolfpack Posted February 26, 2010 Report Posted February 26, 2010 t1000s are good, they only run 1000 wrms at 1 ohm though, so if your running 1 or 2 subs make sure you get dual 4 ohm for the 2 sub configuration and a 2 ohm for 1 sub if you want the 1000 watts, rockford under rates their amps so even a 2 ohm it will push close to 1000 if not more, that is if you have a strong voltage current flowing. good amp though 2010 Subaru Impreza Pioneer AVH-P1400DVD 2 10" Rockford Fosgate Punch HX2 Audison LRx 1.1K superglue a dildo to the center of the cone....lube it.....then have that dumbass sit on it while playing a 10hz note haha, this reminds me of a paintball sticker i have "my balls slap at 300fps" now I want a sticker that says "i fuck at 10hz"
