So im using an old PT amp right now and originally i planned on buying the Rockford Fosgate T1000bd amp, i just realized at 4ohms the RMS will only be 250W, the RMS of the woofers i have are 500W a piece. so what should i buy? an Alpine? a Rockfrod Fosgate?
this is my enclosure
any help is appreciated
EDIT: i found this.
Option 1 (parallel) = 2 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
One 4 ohm DVC Speaker = 2 ohm load
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
One 4 ohm DVC Speaker = 8 ohm load
so i can indeed wire the 2 woofers down to a 2ohm load and push 500W RMS to them?
Edited by psx2p
01 GMC Sonoma 4x4
RF T1500.1bd
DC LVL 4 12"
You have 2 sub with D4 coils right? That means you can wire them to 1ohm, and get the most out of the RF P1000-1bd which does 1000rms@1ohm.
yea there both dual 4ohm coils, how would i go about wiring them?
01 GMC Sonoma 4x4
RF T1500.1bd
DC LVL 4 12"
Its real simple your amp puts out 1k rms at 1 ohm...2 dvc 4 woofers and you want to wire them at 1 ohm. Wire the positives tgether and all the negatives.
I dont know how to put up pictures but go to rockfords site and go to the wiring wizard under support. Select 2 woofers then 2x4 for 2 woofers that are 4ohms. then hit the find button. Will be the first diagram showing a 1 ohm load.
wow, thanks man! :yahoo:
01 GMC Sonoma 4x4
RF T1500.1bd
DC LVL 4 12"
  • Who's Online   1 Member, 0 Anonymous, 1482 Guests (See full list)
