Guest jbinn Posted February 17, 2010 Report Posted February 17, 2010 Okay I made a post about 3 months ago about my subwoofer kicking halfway off (halfway because it still works but it's at like half power) so I took suggestions and check: Battery output - Fine Amplifier Input - Fine Speaker Output - 28.28v Amplifier about half gain Checked subwoofer coils/wiring - All in intact coils look good Switched RCA's - Seemed to make the problem stop temporarily Redid ground/power - Those are on secure with very good connection Opened amplifier - All solder joints are fine and no charring looks brand new Check RCA on amplifier - doesnt wiggle, seems connected. The only thing I havn't done: Ground RCA Try new AMP Try new Sub MY FI is like 3 months old IF that more so 2 months and seems to be runnnig perfect when it works haha.. amplifier has NEVER given me ANY problems before used to run two COMP 15" off it 250RMS each. ONE THING that might help is I put my whole system in my friends car except with a different HU and it seemed to not kick off once on a 8 hour drive... But the weird thing is my system only kicks off at curtain times, I was bumping it all morning and it didnt do it ONCE then I go inside burn a CD go throw it in the car and BAM it does it for like 30 minutes, I wiggle some wires around and stuff eventually it just randomly kicks on (not due to wire wiggling this was AFTER i was wiggling them.) check box terminal and solder joints are FINE.. guys i cant figure out with the life o fm ewhat it would be... the HU has been babied and the amplifier as well and the subwoofer is brand new and should take more abuse then what I give it for a Fi SSD 15" Copper coils D1... The HU is a Pioneer deH-1100 it's really old and I heard that Pioneer decks have a lot of ground problems, but I have no IDEA how to ground my RCA's from my HU any guides for that? also the friend that I ran my system on, we used RCA adapter because he has a factory unit it didnt hit as hard or sound as good but it NEVER kicked off the whole ride from maine to CT and back. Quote
blackrosetiger Posted February 17, 2010 Report Posted February 17, 2010 My advice would be just to switch out HUs that seems to be the problem (Im a Maineiac too BTW) Quote 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
Guest jbinn Posted February 17, 2010 Report Posted February 17, 2010 NOTE: I used this SAME setup with my kickers same HU and all and it NEVER did this, started doing it when I got the Fi but I checked ALL Fi connections including coils and ti seems fine and like I said the damn thing is brand new never been abused. Never smelled anything from it, dont see any coil charring nothing at all. Quote
BeatBox Posted February 17, 2010 Report Posted February 17, 2010 (edited) yeah id replace the head unit, id look for a cheap used one so that incase its not the problem you dont loose your $$$ EDIT: heres a pic of the best way to ground the RCA's Edited February 17, 2010 by BeatBox Quote
Guest jbinn Posted February 17, 2010 Report Posted February 17, 2010 (edited) My advice would be just to switch out HUs that seems to be the problem (Im a Maineiac too BTW) That's what I said too but the weird part is my kickers never did this on the SAME headunit but then again, when I put this whole setup in my friends car aside from the HU it played fine so its a toss up between bad RCA/HU or bad Fi SSD but im going to single out the subwoofer being bad last since I paid $300 for it 2 months ago and babied it... if it's dead already from that then I shall not buy Fi again lol. i need a new HU anyways and if im going to buy one im not gonna go cheap probably go with an Alpine CDA-9885 or something that I KNOW will last me a long time and output great results... but I really want to make that my last options since im broke as a joke and unemployed. Edited February 17, 2010 by jbinn Quote
Guest jbinn Posted February 17, 2010 Report Posted February 17, 2010 (edited) yeah id replace the head unit, id look for a cheap used one so that incase its not the problem you dont loose your $$$EDIT: heres a pic of the best way to ground the RCA's ok ill try that sometime looks kinda of easy and difficult at the same time haha. I just remember though that my RCA's on my HU sink in they don't stick out like that heh... so that tecnique wil not work. Edited February 17, 2010 by jbinn Quote
BeatBox Posted February 17, 2010 Report Posted February 17, 2010 not at all just get some speaker wire and loosen the screw and tighten it up after you run the wire around the outside of the RCA's. And i think there was someone on here selling some alpine decks that looked pretty nice, might wann do that. might be cheaper too. Quote
Guest jbinn Posted February 17, 2010 Report Posted February 17, 2010 not at all just get some speaker wire and loosen the screw and tighten it up after you run the wire around the outside of the RCA's. And i think there was someone on here selling some alpine decks that looked pretty nice, might wann do that. might be cheaper too. Sound good now how bad is this problem? has anoyne ever had anything similar i cant find ANYONE having a subwoofer only half kick off it's incredible weird could RCA's or a bad deck even cause this? Quote
Guest jbinn Posted February 18, 2010 Report Posted February 18, 2010 ok tonight while I was bumping it happened again so I grabbed the front of my deck for kicks and motioned an up and down movement to my friend going "I wish this fixed my problem haha" in that time the subwoofer kicked on, I pulled the deck down and it kicked off finally I realized what it was... my RCA's... so now I have to ground my HU better/RCA's and get better/new rca's hells yeah or just a new HU lol Quote
BeatBox Posted February 18, 2010 Report Posted February 18, 2010 Thats good lol ground them first and get good RCA's if it dont work then a new deck! Quote
