tdc3187 Posted February 19, 2010 Report Posted February 19, 2010 Is is better to go directly to the frame or just find a nice thick piece of metal somewhere close. Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
blackrosetiger Posted February 19, 2010 Report Posted February 19, 2010 Frame always frame. If you think about it a little EVERYTHING grounds to your frame or your motor (which grounds to your... you guessed it! your frame!) 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
tdc3187 Posted February 19, 2010 Author Report Posted February 19, 2010 thanks, that was my intentions but then I got to wondering when I saw this: Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
kmalinich Posted February 20, 2010 Report Posted February 20, 2010 Not really sure what that's a picture of...
wolfpack Posted February 26, 2010 Report Posted February 26, 2010 if you can always got to the frame, my friend grounded his amp to the metal floor of his trunk with long enough screws to go far enough through, used a bolt and ran another wire to the frame, if its a small amp, up to 1000 wrms you can get away with what you took a picture of. 2010 Subaru Impreza Pioneer AVH-P1400DVD 2 10" Rockford Fosgate Punch HX2 Audison LRx 1.1K superglue a dildo to the center of the cone....lube it.....then have that dumbass sit on it while playing a 10hz note haha, this reminds me of a paintball sticker i have "my balls slap at 300fps" now I want a sticker that says "i fuck at 10hz"
bustedassblazer Posted February 26, 2010 Report Posted February 26, 2010 if you can always got to the frame, my friend grounded his amp to the metal floor of his trunk with long enough screws to go far enough through, used a bolt and ran another wire to the frame, if its a small amp, up to 1000 wrms you can get away with what you took a picture of. if the car has a frame(UNIBODY)..plus the entire body of the car is usually an excellent ground....and with that pic..i really dont suggest using an existing bolt...i always use a new stainless and bolt with lock washers and nylon threaded nut...i always check for clearance and use a wire brush on the end of my drill..clear to nice shiny bare metal...drill the hole the size of the bolt and thread it SUPER tight...end all be all under high current applications..run a ground all the way back up to the negative battery terminal...trust me..0 gauge is alot better conductor than the frame 1996 S-10 Blazer Kenwood DNX-6140 (2)Kinetik HC2000 (2)US Amps MD3Dv2 US Amps MD42v2 (4)Hertz HCX-165 (front doors) (2)Hertz HL-70 (dash) (2)Hertz HT-25 (dash) (2)Hertz SX-380D
