NcHalfrican Posted February 22, 2010 Report Posted February 22, 2010 I want to run 12 DD 510's(4 ohm SVC) woofers on 2 SAZ-2000D's...would it be possible to wire this? like 6 subs on 1 amp? Quote
fritosaregood Posted February 22, 2010 Report Posted February 22, 2010 I want to run 12 DD 510's(4 ohm SVC) woofers on 2 SAZ-2000D's...would it be possible to wire this? like 6 subs on 1 amp? Six in parallel would be .66 per amp. Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
uhoh_45 Posted February 22, 2010 Report Posted February 22, 2010 go to bottom Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
NcHalfrican Posted February 22, 2010 Author Report Posted February 22, 2010 Would the SAZ-2000d's be able to handle that ohm load? Quote
raytard Posted February 22, 2010 Report Posted February 22, 2010 yea, it would be all paralleled is .67ohm to each amp...i guess a sundown could handle that after box rise so long as your electrical is good. series 3 and parallel, you get 6ohm, parallel 3 and series is 2.67ohm (if you wanted to strap or use amps that like 2ohm) or run 4 small amps at 1.33 or 1 big amp at 1.33 get to it Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
NcHalfrican Posted February 22, 2010 Author Report Posted February 22, 2010 go to bottom oh nice, thanks bruh Quote
NcHalfrican Posted February 22, 2010 Author Report Posted February 22, 2010 yea, it would beall paralleled is .67ohm to each amp...i guess a sundown could handle that after box rise so long as your electrical is good. series 3 and parallel, you get 6ohm, parallel 3 and series is 2.67ohm (if you wanted to strap or use amps that like 2ohm) or run 4 small amps at 1.33 or 1 big amp at 1.33 get to it Thanks dude, what would you recommend? as far as how many amps? i like the 1 big amp idea... Quote
NcHalfrican Posted February 22, 2010 Author Report Posted February 22, 2010 Or the recommendations of anyone else Quote
EricR Posted February 22, 2010 Report Posted February 22, 2010 With that many subs, I would do 3 amps, 4 subs per amp. The more subs that are on the amp the more imp. rise you will have. Quote i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
NcHalfrican Posted February 22, 2010 Author Report Posted February 22, 2010 With that many subs, I would do 3 amps, 4 subs per amp. The more subs that are on the amp the more imp. rise you will have. Alright, thanks man Quote
