Reallunacy Posted March 1, 2010 Report Posted March 1, 2010 Ok, I have a 2002 Dodge Intrepid. I went to do the big three and found out that my battery was under the air intake and even with that removed the negative terminal was unaccessible. So I decided to move it to the trunk. When I tried to connect the final wire to the battery it sparked a LOT. I decided to put a fuse in but when I did it blew the fuse. I wasn't sure what to do so I closed all the doors and anything I knew that may draw current and tried a second fuse but it blew as well. (Big three are 1/0 and fuses were 250 amp) Here is the Diagram of what I did. Black lines are negative, red are positive and yellow dot is fuse. The numbers correspond to the following pictures. Photos may be bad since it is now after 1am: 1. This is the jump start point the factory added. I ran a 1/0 wire from the alt to this point: 2. This is the ground I am using up front, it is the strut tower and wasn't used as factory. I sanded it down before connecting the 1/0 wire from the alternator and the engine block: 3. This is the alternator. I connected the factory wiring in photo 1, the ground in photo 2 and the battery's positive terminal in photo 5 using 1/0 wire: 4. This is the engine block. It is connected to the front ground in photo 2 using 1/0 wire: 5. This is the battery. It is connected to the alternator in photo 3 and the rear ground in photo 6 using 1/0 wire: 6. This is the rear ground point and is connected to the battery in photo 5 using 1/0 wire: 7. This is currently my only fuse I have installed and it is in between the alternator in photo 3 and battery in photo 6: This is the original battery location and the reason I decided to make my life hell by moving it to the back. That vented panel leads to the front tire and has to be removed to remove battery and access negative terminal: Any help you can give me is much appreciated. I need to be driving by 5 tomorrow and have only 1 fuse left. Quote
dwright27 Posted March 1, 2010 Report Posted March 1, 2010 (edited) disconnect negative terminal. hook positive terminal up. reconnect negative terminal. if it still blows the fuse make sure nothing isnt getting pinched and everything is hooked up correctly. EDIT: Are the grounds and positives connected on the alternator together ?? Edited March 1, 2010 by dwright27 Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Reallunacy Posted March 1, 2010 Author Report Posted March 1, 2010 Are the grounds and positives connected on the alternator together ?? ...yes, i didn't see another place to connect it. where is it supposed to go? Quote
dwright27 Posted March 1, 2010 Report Posted March 1, 2010 (edited) ...yes, i didn't see another place to connect it. where is it supposed to go? HOLY FUCK!!!!!! dude disconnect that shit lol. EDIT: thats your problem. Edited March 1, 2010 by dwright27 Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Reallunacy Posted March 1, 2010 Author Report Posted March 1, 2010 HOLY FUCK!!!!!! dude disconnect that shit lol. EDIT: thats your problem. Ok, removed it. and seems to have power going through just fine now, though I haven't cranked it. So is there not supposed to be a ground from the alt? In this thread no one corrected me. I'm glad you caught it though. Quote
dwright27 Posted March 1, 2010 Report Posted March 1, 2010 Ok, removed it. and seems to have power going through just fine now, though I haven't cranked it. So is there not supposed to be a ground from the alt? In this thread no one corrected me. I'm glad you caught it though. negative on battery to engine. negative on battery to body/chassis of vehicle. positive from positive on battery to alt positive. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Reallunacy Posted March 1, 2010 Author Report Posted March 1, 2010 negative on battery to engine. negative on battery to body/chassis of vehicle. positive from positive on battery to alt positive. Thanks man you're a lifesaver. Quote
dwright27 Posted March 1, 2010 Report Posted March 1, 2010 Thanks man you're a lifesaver. no problem. thats what we are here for. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
skittlesRgood Posted March 1, 2010 Report Posted March 1, 2010 (edited) haha, - and + on the same terminal. thats some big time fail. glad your car didnt burn down man. the alt does need a ground. find any other bolt on the engine for a ground point. i just used one of the bolts that hold the alt to the engine. Edited March 1, 2010 by skittlesRgood Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
kx519 Posted March 1, 2010 Report Posted March 1, 2010 GOTDAMNNN. Good catch. Quote 84 K5 Blazer 3" body, 2" Suspension 35" Maxxis Bighorn 100amp Alt Marine deep cycle for the amps (freebie) KnuKonceptz 1/0 8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz Audiopipe AP-18001D RF 5x8's in the kicks Almani 5.25 comp. in back Kenwood KAC-645 --IN THE FUTURE-- None. <!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
