how to fix
still pops ray should ill try a pop stopper device
Edited by ARMYSGT_D
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
Your amp is coming on and powering up before your HU puts out any output through your RCAs. Amp is already on and then your HU puts out signal and POP!
Either replace the HU or get or make a delay device that makes your HU come on and gives your amps a few seconds of delay. Then the pop will stop.
I had this problem as well. Also- Different types of amps come on and go off at different times. Really annoying. I use 2 really really old MTX LSB-1 bass processors with turn on/off delay to fix it.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
thanks for breaking it down ill go ahead and get the stinger pop stopper or do u have a link to a better 1
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
i got all my remotes on an on off switch running off a relay even if i cut it on after the hu is loaded and playing it still pops
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Guest Scylloga
What causing the pop when I shut it off?
And could you link me to somewhere that shows how to rectify this?
How many poles on your switch? If it's a switch that needs to be grounded and you didn't that'll make it go pop. Biggest case in point is illuminating switches, if you don't attach the ground for the light (because you don't want it to light up) you will get pops.
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 958 Guests (See full list)
