and it looks fuckin SWEEEEEEEEET!
What kind of sub is it?
Edit: Oops, Asking the wrong person. :D
84 K5 Blazer
3" body, 2" Suspension
35" Maxxis Bighorn
100amp Alt
Marine deep cycle for the amps (freebie)
KnuKonceptz 1/0
8 Hifonics HFi 12D4's in ~19cubes tuned to 35hz
Audiopipe AP-18001D
RF 5x8's in the kicks
Almani 5.25 comp. in back
Kenwood KAC-645
--IN THE FUTURE--
None.
<!--quoteo(post=0:date=Feb 3 2010, 09:12 AM:name=Decaf)--><div class='quotetop'>QUOTE (Decaf @ Feb 3 2010, 09:12 AM)</div><div class='quotemain'><!--quotec-->we seriously need some butt plugs so you guys stop spewing chit talk<!--QuoteEnd--></div><!--QuoteEEnd-->
no its not just switching the + & - thats switching polaritys which is a no no. Inverting a sub refers to actually mounting sub upside down in the box with the basket out side of the box. Read up more on Free Air Boxes before you try this. As with all installs it depends on the users preference. And what they're using for a Sub, Amp, & Wireing
Sorry but you're wrong. Doesn't matter if the sub is mounted regular or inverted, it still uses the box.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
correct me if im wrong but i thought switching phases only matter if one sub is inverted and the other is not.
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
Nope can't find where I said that it doesn't use a box..... and yet still its a type of free air system Box TypesYes It does still use the air inside the box but the majority of the air it uses is "Free Air"
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
No man you're wrong, inverting subs in a regular ported box has nothing to do with free air.
A free-air system consists of woofers mounted to a board attached to the rear deck or placed in the trunk against the rear seat. The trunk of the car acts as an enclosure which houses the subwoofer and isolates sound from the back of the speaker, solving the sound cancellation problem of subs without an enclosure.
Free-air systems save space and have flat frequency response. The woofer must be specifically designed for free-air use. The lack of a box makes them more convenient to install, but their power handling levels are usually much lower than their boxed counterparts
fail
you're thinking infinite baffle which is completely different. and you have to use a speaker made for an ib setup
That's Infinite Baffle.
My Youtube Page. Check it out
The "SAV" - Sub-aural Assault Vehicle
Kenwood eXcelon KDC-X993
Image Dynamics CTX 6.5" Components
Q-logic 6.5" kick pods
CDT 6.5" CL-E6NEO Front door Midbass
Kicker ZX350.4
Knukonceptz SS Karma 4 channel 6m RCA
Fi Q 18" w/ brushed aluminum dust cap
7cu ft. ported box tuned to 28hz
Sundown SAZ-1000D
Iraggi 240 amp Amputator Alt
Big 3 in Monster 1/0awg
Second Skin Damplifier Lite on roof and front doors
look at my picture mines inverted in a 3.5 cube tuned to 36 hertz a while back we had a dicussion about weather you need to reverse polarity I was led to believe that you needed to so mines reversed but some of the people on here said you didn't need to either way it will play just fine reversed or in the box I just did mine for looks
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
whoever said reverse the + and - is wrong too
you only do that if one sub is inverted and the other is normal
it is still going to be the same wiring
Wouldnt be thehoe92 without teh purple
  • Who's Online   0 Members, 0 Anonymous, 463 Guests (See full list)
