Can i port through the rear deck of my car?
Yes, it is possible.
The only way to find out it is worth it, is testing and measure!
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
you def could, by either cutting the rear deck out to fit a port, or taking out ur rear speakers, and just running a pvc or aero port through it. that would allow the port to get into the cabin, ESPECIALLY if ur seats dont fold down. just make sure u cut to the right length or else ur tuning will be off.
Lol I was thinking of doing the exact same thing. In theory it should make it a hell of a lot louder.
Edit: Are you keeping your rears?
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
i was thinking the same. i was going to cut a small area between the rear speakers and just put some grill cloth over it . im thinking it would cut down on some of the rattling up there
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
if you want to do a true port through the box is two parts the ported half and the sealed half its a band pass enclosure now if you are just thinkin of buildin a conventional box with subs back port through the rear deck not sure how it will sound you can give it a try and let us know
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
  • Who's Online   1 Member, 0 Anonymous, 2011 Guests (See full list)
