Whenever I start my car my bass kicks real hard, even with nothing playing, it's done this with every amp I've had, now i can also hear the bass a little bit when I turn the volume on my hu up and down, is it a bad ground on my amp or hu/rca's? Or is it something else? I don't feel like ripping everything apart if someone knows right away. <lazy>
Start out boxy, shape as you move along.
Dc Audio
Team Fur
what do you have your remote wire hooked up to?
the headunit
and you said this same exact amp has done this in every car you have put it in?
nooo lol every amp in the same car, same hu same ground connections
Dc Audio
Team Fur
i had the same problem, mine was because i ran 5 runs of 0 gauge wire over my rca cables, after i switched em up, the noise went away
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
okay. if it is making a pop noise when the amp initially turns on then your headunits turn on might be f'd up
you can install something like this:
http://www.sonicelectronix.com/item_18693_PAC+TR-4.html
it could also be that your rca's need to be grounded. what kind of headunit do you have?
yea. run your rca's on the opposite side of the car as your power and remote wire
if you have cheapo rca's they will pick up signals from the power wire
