it depends how big each chamber would be but there is nothing wrong at all with them all sharing the same air space
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
the box would be 17.6 cubes on the in side but with all tha wood inside it would be about 3.25 each chamber
3.25 is too much for L5's IMO
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
this is what kicker.com says
Model S12L5
Size (IN.,CM) 12, 30.5
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1200/600
Sensitivity (dB 1w/1m) 86.9
Frequency Response (Hz) 20-100
Mounting Depth (IN.,CM) 6-13/16, 17.3
Mounting Cutout, Square (IN.,CM) 11-1/16, 28.1
Min Rec Sealed Box Volume (CU. FT., Liters) .88, 24.9
Max Rec Sealed Box Volume (CU. FT., Liters) 2.0, 56.6
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 3.25, 92.1
^^^^^ 3.25 is way to big per sub IMO.
96 IMPALA SS
Pioneer DEH-P8600MP H/U
Pioneer TS-C160R 6.5"
Pioneer TS-D690R 6x9"
JBL GTO755.6II
Stinger spdh-10 cap
100sqft. Fatmat
AQ 3500d
18" FI BTL 7cuft 35Hz
how much should each sub get???
I would probably go about in the middle around 2.5 cuft per sub maybe alittle less. I mean you can build it any way you want but I think you would be happier with a smaller box. How much power are you gaonna feed each one?
Edited by KAPONE.SS
96 IMPALA SS
JBL GTO755.6II
Stinger spdh-10 cap
100sqft. Fatmat
AQ 3500d
cool, should i do 2 chambers w 2 subs in each or just one big box
  • Who's Online   0 Members, 0 Anonymous, 7334 Guests (See full list)
