dakidd7891 Posted March 18, 2010 Report Posted March 18, 2010 on re's website they have this description. 15" Electrical Q Value -Qes: 0.58 Mechanical Q Value -Qms: 3.62 Total Speaker Q Value -Qts: 0.501 Free Air Resonance -Fs: 19.10 Hz Equivalent Compliance -Vas: 207.0 liters One-Way, Linear Excursion -Xmax: 54 mm Efficiency -SPL 1W/1m: 85.81 dB SPL Effective Piston Area -Sd: 810 cm^2 DC Resistance -Re: 4.2 ohm Nominal Impedance -Znom: Dual 2 ohm Thermal Power Handling -Pe: 2000 W Force Factor -Bl: 18.16 i dont see rms handling. is thermal power handling their way of saying rms? NEW ORLEANS SLAP Alpine CDE-103BT 2 12'' JL Audio W3v3-4 Hifonics HIF1500.1
RE XXXV3 Posted March 18, 2010 Report Posted March 18, 2010 Yes. They recommend (Recommended Manufacturer Settings?) not going over it's thermal handling where power = heat. If you had liquid cooling and the cone could handle it than it'd handle more.
IH8PunkRok Posted March 18, 2010 Report Posted March 18, 2010 lol rms means root mean square thermal handling will be your rms -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
