Crossover Or Not?
qbert
i got 4 selenium st200 and 4 selenium 6w4p running off a JL Audio 600.4HD amp and the guy i got them from said id be just fine running the of the amp crossovers.
Now the amp crossover goes from 50 to 500hz think that will be fine?
All speakers are 8 ohm so i was going to wire 2 st200 to make a 4ohm load for the front right and the same on the front left and put 2 6"s wired to a 4ohm load to the rear right channel and the same to rear left.
05 XB
HU - Alpine IDA-X305
Front - 4 Selenium ST200
Rear - 4 Selenium 6W4P
Mid - 4 Selenium 8W4P
Front Rear Amp - JL Audio 600.4 HD
Mid Amp - JL Audio 600.4 HD
I would say no. If you have any questions call partsexpress.com. They should have the answer for you.
03 350Z
Id like to build one can someone help me design a crossover setup?
2 ST200 wired to 4 ohms (LEFT SIDE)
2 ST200 wired to 4 ohms (RIGHT SIDE)
2 6W4P wired to 4 ohms (LEFT SIDE)
2 6W4P wired to 4 ohms (RIGHT SIDE)
Any Help Would be Great.
05 XB
hit up parts express they can help you build your own. You need to do some research and find out what frequencies these things like. Then, you can go from there at what you want your cut offs to be at. It will be a heck of a lot easier after that.
03 350Z
  • Who's Online   0 Members, 0 Anonymous, 1401 Guests (See full list)
