rocknwoo Posted March 26, 2010 Report Share Posted March 26, 2010 If your using two woofers and the slot port is on the middle of the two woofers, and if the port is to long and has to T off to the back of the box, does the port width that 90s to the left and right has to equal the middle port width? So for example if the middle port width is 4" the port width that 90s to the left and right would be 2"? Thank Link to comment Share on other sites More sharing options...
Guest Posted March 26, 2010 Report Share Posted March 26, 2010 iirc when the port splits off it has to be half the size of the main port (where the 2 smaller ports join together) so if you have a 3" main port, it would split off into 2 1.5" ports. so yea it would split off into 2 2" ports Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 26, 2010 Report Share Posted March 26, 2010 if your port needs to be 2" wide the back wall will be 2" and where they meet should be 4" R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
rocknwoo Posted March 26, 2010 Author Report Share Posted March 26, 2010 Thanks for the reply I got confused because dj from audioque told me to make them the same as the middle, unless I heard him wrong. Thanks again Link to comment Share on other sites More sharing options...
