Hey guys I decided to run (2) B&C 6PEV13 6.5 Mids and (2) B&C DE35 Bullet Tweeter in each front door. I plan on purchasing a active Headunit to tune the system. Can anyone tell me what range or xo point I should run to these speakers? Also I need to purchase an amp for these speakers would someone please recommend an amp as well to power this.
Thanks
B&C 6PEV13 SPECS
Nominal Diameter 170 mm (6.5 in.)
Nominal Impedance 8 Ω
Minumum Impedance 6 Ω
Power Handling
(300-3000 Hz)
Nominal1 120 W
Continuous Program2 240 W
Sensitivity (1W/1m)3 99 dB
Frequency Range 150-8000 Hz
Voice Coil Diameter 38 mm (1.5 in)
Winding Material Aluminium
Former Material Fiber Glass
Winding Depth 7 mm (9/32 in)
Magnetic Gap Depth 6 mm (1/4 in)
Flux Density 1.4 T
Thiele & Small Parameters4
Fs 126 Hz
Re 5.2 Ω
Qes 0.39
Qms 4.6
Qts 0.36
Vas 6 dm3 (0.21 ft3)
Sd 132 cm2 (20.5 in2)
η0 3%
X max ± 0.6 mm
X var ± 1.5 mm
Mms 6 g
Bl 8.2 T·m
Le 0.6 mH
B&C DE35 SPECS
Nominal Impedance 8 ohm
Minimum Impedance 7 ohm
Nominal Power Handling (1) 25 W
Continuous Power Handling (2) 50 W
Sensitivity (1W/1m) (3) 108 dB
Frequency Range 3.5 -18 kHz
Recommended Crossover (4) 5 kHz
Voice Coil Diameter 32 mm (1.25 in)
Inductance 0.1 mH
Diaphragm Material Mylar
Flux Density 1.3 T
  • 2 months later...
Thanks
B&C 6PEV13 SPECS
Power Handling
(300-3000 Hz)
Nominal1 120 W
Flux Density 1.4 T
Fs 126 Hz
Re 5.2 Ω
Qes 0.39
Qms 4.6
Qts 0.36
η0 3%
X max ± 0.6 mm
X var ± 1.5 mm
Mms 6 g
Bl 8.2 T·m
Le 0.6 mH
B&C DE35 SPECS
Inductance 0.1 mH
Flux Density 1.3 T
Id go with somthing quality for a amp iv always had good luck with Old school rockfords and eclipse is a decent amp depending on your budget for a little cheaper the new hifonics amps are ok go with sumthing 400X2 or 600X2 run your 6.5 and horn togather + to + and - to - soo it will run at 4 ohms u can even run another horn in there or another 8 ohm speaker to drop it to 2 ohms... but a decent crossover for the horns!! u can check with parts express tech support n they will recomend one for u
  • Who's Online   1 Member, 0 Anonymous, 1487 Guests (See full list)
