Okay I just got a quad sub enclosure it is home made but for 20 dollars i couldn't pass it up How do i measure it to know what 12's i can run in it? thanks for the the help!
you need to know the height, width, and depth. how thick is the wood. say it is 3/4" then subtract that from each side (so if your width was say 50, then you would subtract 1.5" and use 48.5 as your width(Do this for all sides) then multiply the width depth and height. then divide that number by 1728 and you will have your cubic feet, then just divide that by four and you will know how many cubes you will have per sub
