Using A sub amp RCA Pass Thru ?
Crump
RFITY-1F
2 of them
one for left and one for right, problem is, will it be long enough to reach both amps
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
RFITY-1F
2 of them
well off of the splitter cant I just run an Rca to my amp?
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
im being complicated and i apologize, im tired, just trying to give you the options
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
Why are you running another amp for your tweeters, not just cut in to your front speakers?
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
Well I was thinking about running my two rear channels @ 2 ohms each. 1 for my 4 tweets (2 per crossover) and 1 for my two rear speakers.
the tweets are going in the rear deck
If it were me I would just tap into the speakers that are already there. No need for another amp imo, maybe someone else will have a different opinion but as long as the tweets can handle the power... What are the tweets, is it a component set of speakers or just tweets you are adding on
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
also if they are going in the rear i would use the rear rcas if you are still bi amping
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
Heres my options
1. 4 tweeters take up 2 channels get 50 watts each 4 door speakers get 50 watts each
2. 4 tweeters take up one channel and get 25 watts per channel, 2 rear speakers get 50 watts each, 2 fronts get regular wattage
and they are tweeters from my old component system. but Im just not using the speaker
these
as far as i have ever heard, not stating fact here, but i have heard that tweeters dont really mess with impedance and take away from power. what do you have for fronts? if you have the fronts covered, then I would just hook both sets of tweets to the one cross with the woofer on the other side and forget the other amp but im going to bed, ill check back tomorrow and maybe agreed with or told im wrong, we shall see
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
  • Who's Online   0 Members, 0 Anonymous, 1183 Guests (See full list)
