First of all Meade your work ROCKS!
Reading and seeing your progress on that MAC build you did inspired me a couple months back to start my own PC build on NitroForumz.com under the name 1m2's NiTRO-Puter
PC=Zotac Ion Atom 330 Dual Core Mother board that has 3 options for audio outputs.
has 3 3.5 mini jacks (front, rear, cntr/sub)
has 1 optical out
has 1 digital coax out
(I'm 99.99% sure they can be changed to inputs/outputs)
I purchased a bluetooth dongle for the PC as well
HU=Kenwood KDC-X993 w/bluetooth
(I'm not a fan of Pioneer any more otherwise I would have gone w/one like yours.)
the Kenwood has the following
3 pairs of RCA outputs
has 1 USB input (supports FAT16/32 Harddrive)
has 1 3.5 mimi jack input (which is only stereo I believe)
and the bluetooth.
So what I want to accomplish is to have the PC output going into Kenwood input so that the radio does the audio processing but I doubt I'll be able to input 5.1 into the HU even if the bluetooth was working.
With that said the PC's sound card sounds crappy even w/amps so what can I use to correct this?
Do I need some sound processor or some thing else cause I can go from HU to PC, then to amp's but I need some thing to help w/sound quality if I'm playing music off PC.
Any recommendations from SMD or fellow Audio Geeks would be appreciated.
2017 Ford EcoBoost Mustang, Grabber Blue
Single 10" Dual 2 OHM Skar EVL 4thOrderBandpass
doors & rear all Orion
Custom 1 of a kind 15" Android.
What IS the sound card in the first place?
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
it's the actual on board sound card, no additional slots available on this MoBo because the only 1 extra it has is being used by a WiFi card. Don't remember specifics other than what I put above already.
nice set up by the way blackrosetiger
Edited by 1miracle2
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-098
That ought to do the trick. Go from the 3.5 mm (headphone jack) output on the PC to the 3.5 mm input on the HU.
Not sure why you have 3 outputs for headphone jacks, but we can always do this:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-096
Have 3 of these coming out of your 3 computer outputs (front, rear, center/sub)
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=249-146
Daisy-chain 2 of those fuckers together so your 3 inputs become 1. Then run this:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-094
to your HU.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
http://www.parts-exp...tnumber=240-098
http://www.parts-exp...tnumber=240-096
http://www.parts-exp...tnumber=249-146
http://www.parts-exp...tnumber=240-094
to your HU.
Maxim thanks for the links! I know I can run the 3.5 from PC to HU and if that's what I have to do I will.
I'll keep looking for more suggestions to see what else I can do. I'm curious how Steve Meade did it on his Hoe, last time I checked there was no diagram of how he connected that HU w/his MAC input/output.
holly molly!
I can't believe how many posts for help were posted today!
No wonder SMD can't get around to answering questions.
F' it! I might just go w/3.5 from PC to HU. :-(
to your HU.
Sorry that suggestion is just stupid. That is a splitter, you can't take three sources and combine it into one. Take the 3.5mm front left and right output from your pc directly to the input of the HU. There is nothing else to it, really simple. The three other outputs are for different channels, intended for a 5.1 setup.
Edited by Moti
Moti I was trying to be nice and not start calling any one names since I'm asking for advice but yes I know that can't be done.
And I know I can use PC 3.5 out to HU 3.5 in.
I was hoping some one knew of some kind of sound processor where I can do some thing like.
3 RCA outputs from HU to PC 3 3.5 inputs. Then use optical or digital coax output on PC into some kind of processor that also has 3 sets of RCA or 3.5 jack outputs that I can push to amps. Does that make sense?
Thanks everyone for your suggestions and thoughts!
After reading 102 pages of the Hoe "Mac'd out" I finally found what SMD did.
He went from MAC 3.5 mini output to HU (Pioneer) 3.5 input.
Then renamed his source on the HU to say "CarPuter"
I'm still skimming through the pages though so he may have changed it.
I also noticed a lot of smack talk though! LOL
A few people making comments they don't have facts on.
I also noticed some thing else... SMD posts ton's and ton's of pix and video's which is awesome!
I along w/others who aren't so savvy on wattage, +, -, amperage, voltage, wiring would really appreciate some diagrams.
I know he's doing a TON of work and I'm sure I'm on the only one that uses forums to learn sh!t.
I haven't gone through this forum in/out's so I don't know if there is a section for wiring diagrams or what not.
my 2 cents, don't freak out w/jerk comments, just posting my thoughts.
All in all SMD's work is off the charts, the forum members are pretty cool too!
People are straight forward and no one takes sh!t to heart.
Good Times!
I just thought it wasn't a brilliant idea nor was I calling him out...
The 3.5mm should be fine... unless you want to dish out a lot of money for a digital processor. I wouldn't do that unless you are running all high end sq type equipment. You can change the output format if you are worried about sound quality.
Simply use the PC as a media source. You can skip the HU if you want to by getting something like a audison bit one and using the optical out from the pc to the processor. Take the preouts from the processor to your amps.
  • Who's Online   0 Members, 0 Anonymous, 923 Guests (See full list)
