UMGixxer Posted April 15, 2010 Report Posted April 15, 2010 Does it hurt anything to run your power wires thru your box? I have done it before but I use a pvc pipe for the wires to run thru.
teamace24 Posted April 15, 2010 Report Posted April 15, 2010 Im assuming your talking about the power wires from your amp and not your subs right? Just in case, with subs that is perfectly fine as that is how i do mines. If its the amp, can i ask how are you doing this, are you mounting the amp on the box? Either way the wire is not going to be damaged or damage your box since it already has the insulation on it to protect it. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
