Kvo_8 Posted April 17, 2010 Report Share Posted April 17, 2010 Ok so the other night I got was installing a radio in my 03 Acura rsx, I got all the wires hooked up correctly and everything but the headunit did not power on. I thought this was odd so I hooked up the headunit to a 12v battery to see if it worked and it did. The car also had a aftermarket headunit installed before. I bought a new Acura harness because I thought it could be faulty, switched it out and nothing. I then hooked up the red power on the alpine 9886 harness with the car's red wire and I also added the yellow wire together with the reds and it powered on. Now everything works but doesn't hold my settings and such. Any ideas on what I could do? Basically the yellow wire on the car harness is dead Quote Alpine 9886 Polk Audio 6.5 Component db series Elemental Designs nine.4 JL Audio 1000/1 DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz Clarion EQS746 Stinger Voltage Meter Optima Yellow Top (Front) XS Power 1200 (Rear) All KnuKonceptz Wiring Link to comment Share on other sites More sharing options...
Coolwazabi Posted April 17, 2010 Report Share Posted April 17, 2010 check the yellow wire while the car is on/off with a DMM and see if its working Quote Link to comment Share on other sites More sharing options...
Berto Posted April 17, 2010 Report Share Posted April 17, 2010 IIRC the yellow is your constant so you could run a wire to the + on your battery and connect red to red. It doesn't save any of your settings because your constant isn't always getting power. Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k Link to comment Share on other sites More sharing options...
hondaonchrome Posted April 17, 2010 Report Share Posted April 17, 2010 Ok so the other night I got was installing a radio in my 03 Acura rsx, I got all the wires hooked up correctly and everything but the headunit did not power on. I thought this was odd so I hooked up the headunit to a 12v battery to see if it worked and it did. The car also had a aftermarket headunit installed before. I bought a new Acura harness because I thought it could be faulty, switched it out and nothing. I then hooked up the red power on the alpine 9886 harness with the car's red wire and I also added the yellow wire together with the reds and it powered on. Now everything works but doesn't hold my settings and such. Any ideas on what I could do? Basically the yellow wire on the car harness is dead You could run the yellow wire directly to your battery(make sure you put a inline fuse inbetween) and run the red wire to anywhere that has power when the key is in the ignition.I had an 02 rsx type-s but never had this problem. Quote Link to comment Share on other sites More sharing options...
Kvo_8 Posted April 17, 2010 Author Report Share Posted April 17, 2010 What gauge wire and what size fuse should I use?? Quote Alpine 9886 Polk Audio 6.5 Component db series Elemental Designs nine.4 JL Audio 1000/1 DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz Clarion EQS746 Stinger Voltage Meter Optima Yellow Top (Front) XS Power 1200 (Rear) All KnuKonceptz Wiring Link to comment Share on other sites More sharing options...
hondaonchrome Posted April 17, 2010 Report Share Posted April 17, 2010 What gauge wire and what size fuse should I use?? It dont have to be thick,your only powering a radio,maybe a 10-15 amp Quote Link to comment Share on other sites More sharing options...
Kvo_8 Posted April 17, 2010 Author Report Share Posted April 17, 2010 Would 16 gauge wire be ok?? Quote Alpine 9886 Polk Audio 6.5 Component db series Elemental Designs nine.4 JL Audio 1000/1 DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz Clarion EQS746 Stinger Voltage Meter Optima Yellow Top (Front) XS Power 1200 (Rear) All KnuKonceptz Wiring Link to comment Share on other sites More sharing options...
Berto Posted April 17, 2010 Report Share Posted April 17, 2010 You could use whatever size you want. Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k Link to comment Share on other sites More sharing options...
hondaonchrome Posted April 17, 2010 Report Share Posted April 17, 2010 yes that would be fine,you could use prolly even remote wire for an amp. Quote Link to comment Share on other sites More sharing options...
Kvo_8 Posted April 17, 2010 Author Report Share Posted April 17, 2010 Thanks again for the help guys. I'll let you guys know how it turns out when I do it. Quote Alpine 9886 Polk Audio 6.5 Component db series Elemental Designs nine.4 JL Audio 1000/1 DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz Clarion EQS746 Stinger Voltage Meter Optima Yellow Top (Front) XS Power 1200 (Rear) All KnuKonceptz Wiring Link to comment Share on other sites More sharing options...
