Limit101 Posted April 17, 2010 Report Posted April 17, 2010 Is there a big difference in quality between 10 inch subs and 12 inch subs. for example a 10 vs 12 inch type r when i say quality i mean the quality of bass
Neo_frog Posted April 17, 2010 Report Posted April 17, 2010 Generally no. Depending on the designs, you could potentially change the resonant frequency of the enclosure, but in most cases it's a negligible amount. With a bigger sub, you gain more cone area and hence have more air movement, but you should pick the subs based on the application and acoustics of the enclosure/car. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
