Boon Posted April 25, 2010 Report Posted April 25, 2010 First off when you disconnect a battery you only need to disconnect the neg terminal (the ground) and second off when you do that it clears some codes in the computer and loses radio stations and eq settings which is annoying Err you know it makes no difference whether you remove the pos or the ground from the battery, you're still gonna clear all your codes, lose your radio stations and eq settings.... You still have no power to the car. Quote 10.x volts fo' life!
