xXx iKoN xXx Posted April 28, 2010 Report Share Posted April 28, 2010 I have a switch hooked up to shut off the HU but that cuts off the amp as well. I have another switch right next to it that I want to have hooked up to the remote to cut off only the amp that way I can still keep the music playing. The switch has two leads and I know one lead connects to remote but where does the other connect to??? PLEASE HELP. Thanks. Quote 1999 Honda Civic DX Coupe Head Unit: Panasonic CQ8100U (Temporary) Front: 6.5" Kenwood KFC-1662S Rear: 6"x9" Kenwood KFC-6989ie Sub: Undecided Amp: Undecided Big 3 Upgrade (4 gauge) Marine Battery routed to the trunk Stock Alternator for now Link to comment Share on other sites More sharing options...
chewie Posted April 28, 2010 Report Share Posted April 28, 2010 on side goes to the head unit and the other side goes to the remote wire going to your amp. Quote 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car... Link to comment Share on other sites More sharing options...
xXx iKoN xXx Posted April 28, 2010 Author Report Share Posted April 28, 2010 on side goes to the head unit and the other side goes to the remote wire going to your amp. are you meaning one end connects to remote lead behind HU and other connects to remote lead on amp? Quote 1999 Honda Civic DX Coupe Head Unit: Panasonic CQ8100U (Temporary) Front: 6.5" Kenwood KFC-1662S Rear: 6"x9" Kenwood KFC-6989ie Sub: Undecided Amp: Undecided Big 3 Upgrade (4 gauge) Marine Battery routed to the trunk Stock Alternator for now Link to comment Share on other sites More sharing options...
xXx iKoN xXx Posted April 28, 2010 Author Report Share Posted April 28, 2010 So if I am understanding this right then one wire goes from REM behind the HU to the switch and the other goes from REM on amp to switch. Quote 1999 Honda Civic DX Coupe Head Unit: Panasonic CQ8100U (Temporary) Front: 6.5" Kenwood KFC-1662S Rear: 6"x9" Kenwood KFC-6989ie Sub: Undecided Amp: Undecided Big 3 Upgrade (4 gauge) Marine Battery routed to the trunk Stock Alternator for now Link to comment Share on other sites More sharing options...
creyc Posted April 28, 2010 Report Share Posted April 28, 2010 So if I am understanding this right then one wire goes from REM behind the HU to the switch and the other goes from REM on amp to switch. Essentially yes. All you're doing is putting the switch in-line with the remote wire. HU--------SWITCH--------------AMP (sometimes pictures are worth a thousand words : ) Quote 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck Link to comment Share on other sites More sharing options...
xXx iKoN xXx Posted April 28, 2010 Author Report Share Posted April 28, 2010 well I will give it a shot. Quote 1999 Honda Civic DX Coupe Head Unit: Panasonic CQ8100U (Temporary) Front: 6.5" Kenwood KFC-1662S Rear: 6"x9" Kenwood KFC-6989ie Sub: Undecided Amp: Undecided Big 3 Upgrade (4 gauge) Marine Battery routed to the trunk Stock Alternator for now Link to comment Share on other sites More sharing options...
chewie Posted April 28, 2010 Report Share Posted April 28, 2010 thats it ^^^^ Quote 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car... Link to comment Share on other sites More sharing options...
xXx iKoN xXx Posted April 28, 2010 Author Report Share Posted April 28, 2010 No GO!!!!!!!!! I added a wire from the AMP REM to a switch and then Added another wire from the HU REM to the switch and it did nothing. Quote 1999 Honda Civic DX Coupe Head Unit: Panasonic CQ8100U (Temporary) Front: 6.5" Kenwood KFC-1662S Rear: 6"x9" Kenwood KFC-6989ie Sub: Undecided Amp: Undecided Big 3 Upgrade (4 gauge) Marine Battery routed to the trunk Stock Alternator for now Link to comment Share on other sites More sharing options...
chewie Posted April 28, 2010 Report Share Posted April 28, 2010 ok.. a switch opens and closes the circuit it would be like you cutting the wire in half and then touching the bare ends to turn it back on.. run the remote wire from the head unit to where you will mount the switch then cut the wire... attach one side from the head unit to one of the tabs on the switch.. then use the other end..(going to the amp to the other tab on the switch... unless you have a light up switch where there is three tabs.. then you use the two that dont say negative. the negative you will ground so when you turn the switch on.. it will light up. Quote 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car... Link to comment Share on other sites More sharing options...
chewie Posted April 28, 2010 Report Share Posted April 28, 2010 i dont understand how you managed to wire your radio to a switch to turn on and off but this simple task eludes you Quote 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car... Link to comment Share on other sites More sharing options...
