help with installing remote kill switch
I have a switch hooked up to shut off the HU but that cuts off the amp as well. I have another switch right next to it that I want to have hooked up to the remote to cut off only the amp that way I can still keep the music playing. The switch has two leads and I know one lead connects to remote but where does the other connect to??? PLEASE HELP. Thanks.
1999 Honda Civic DX Coupe
Head Unit: Panasonic CQ8100U (Temporary)
Front: 6.5" Kenwood KFC-1662S
Rear: 6"x9" Kenwood KFC-6989ie
Sub: Undecided
Amp: Undecided
Big 3 Upgrade (4 gauge)
Marine Battery routed to the trunk
Stock Alternator for now
on side goes to the head unit and the other side goes to the remote wire going to your amp.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
are you meaning one end connects to remote lead behind HU and other connects to remote lead on amp?
Sub: Undecided
Amp: Undecided
So if I am understanding this right then one wire goes from REM behind the HU to the switch and the other goes from REM on amp to switch.
Sub: Undecided
Amp: Undecided
Essentially yes.
All you're doing is putting the switch in-line with the remote wire.
HU--------SWITCH--------------AMP
(sometimes pictures are worth a thousand words : )
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
thats it ^^^^
:popcorn:
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
No GO!!!!!!!!! I added a wire from the AMP REM to a switch and then Added another wire from the HU REM to the switch and it did nothing.
Sub: Undecided
Amp: Undecided
ok..
a switch opens and closes the circuit it would be like you cutting the wire in half and then touching the bare ends to turn it back on..
run the remote wire from the head unit to where you will mount the switch then cut the wire...
attach one side from the head unit to one of the tabs on the switch.. then use the other end..(going to the amp to the other tab on the switch... unless you have a light up switch where there is three tabs..
then you use the two that dont say negative. the negative you will ground so when you turn the switch on.. it will light up.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
i dont understand how you managed to wire your radio to a switch to turn on and off but this simple task eludes you
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
  • Who's Online   0 Members, 0 Anonymous, 1235 Guests (See full list)
