xg3r4dx Posted May 1, 2010 Report Posted May 1, 2010 # 1,000 watts peak # variable high- and low-pass filters (50-250 Hz, 12 dB/octave) # variable bass boost (0-18 dB boost at 40 Hz) # preamp- and speaker-level inputs # preamp-level outputs # thermal, overload, and short protection # fuse rating: 20A x 1 # 10-gauge power and ground leads recommended — wiring and hardware not included with amplifier # 10-3/4"W x 2-3/16"H x 9-1/8"D # warranty: 90 days # Magnum ported dual 10" enclosure: # 5/8" particle-board construction with aviation-grade carpet # two Magnum 10" 8-ohm subwoofers wired for 4-ohm impedance # poly cone with large-roll foam surround # frequency response: 20-300 Hz # power range (each): 200 watts RMS # dimensions: 28-1/8"W x 12-15/16"H x 13-1/8"D1 x 9-3/4"D2 What settings would be ideal LPF: HPF: Gain:
Boon Posted May 1, 2010 Report Posted May 1, 2010 Eeeek 1000w peak and a single 20A fuse, ouch. 90 day warranty doesn't bode at all well either. LPF, set it to between 80 and 100hz. Probably closer to 100 because judging by the amps and subs the fronts probably aren't up to much. HPF, switch it off. Gain, umm somewhere between none and some. People will say set it with a DMM but I wouldn't bother. Just turn it until it sounds good. 2/3rds probably. And about a month from now, please, please buy all new equipment. 10.x volts fo' life!
