ohkay so i have a box its 47 in long and 17 high 14 in deep subs up port up that the best way this sub box would fit. anyways the port is 5x5 and 8 in deep big mistake its 20 sq in of port area haha wow dont laugh. but now how the hell can i fix this problem?? with out changing the whole top of the box.
got pictures, grab a jig saw and cut a bigger hole. build a new port and glue/screw it on.
btw: I just built a new box, because i made my port 4x4x6. Looks nice on paper, but... :drinks:
Edited by tdc3187
Viper 5902, big 3, 1/0 Rockford wiring, 2 xs d3100, mechman 300a, pioneer avic-z1, 2 dc 12xls, Rockford t2500.1bdcp, Rockford t1000.4ad, Rockford t2 6.5 comps, damplifier
Build log: http://www.stevemeadedesigns.com/board/topic/102584-carbon-fusion/
how does it sound?
It sounds good but lots of port noise now. An idk if this matters but now the tensils are hitting the cone harder it has that cushion but I can still here it.
isnt 5x5=25???
what sub are you running?
5 in long 5 in wide it's a little square. I am running two twelf in re somethings ha no one knows what they are ha
What subs?? what amount of power?? if you did that port, i guess you want to hit the lows because it´s a big box and very low tuning.
if the box it´s 47" wide, you have a lot of space to work with, leave the 5" high and get 13" wide, 24" depth (L port) would give you around 36 hz and 2.2 cubic feet for each sub, that would be a very simple but nice box, unless you are using some monsters 12" subs or very tiny power, but once again, i don´t know what subs and power you use...
