why would i max at 1000 when with this 2500 watt boss amp i have on it i am pushing about 1800 and it is fine. i just want a more stable more known amp.
1999 Honda Civic DX Coupe
Head Unit: Panasonic CQ8100U (Temporary)
Front: 6.5" Kenwood KFC-1662S
Rear: 6"x9" Kenwood KFC-6989ie
Sub: Undecided
Amp: Undecided
Big 3 Upgrade (4 gauge)
Marine Battery routed to the trunk
Stock Alternator for now
1 ohm stable amp for 3000 rms you have lots of options, question is whats your budget?
budget is about 300 so even if i could find an amp that is about 2000 at 2 ohm stable.
Sub: Undecided
Amp: Undecided
Its because boss might say 2500 but really its more like 800 rms, whats the size fuses you use on that amp?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Not just trying to push this amp since it's what I'm going with but why not a audioque 2200d. Will do 2200rms @1ohm and somewhere around 1000 @2ohm(2ohm is only a guess) your subs are dual 4ohm subs so you can get a 2ohm or 8ohm load out of one and a 1ohm load out of two.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
well in that case if i can get it wired down to 2 ohm then i would like to find an amp that will push about 1800 on a 2ohm load. and the reason i know i am get that much is because i tested it on my friends kicker 2500.1 and it was the exact same.
Sub: Undecided
Amp: Undecided
What about a SAZ-3000D that will push about 1600 at 2 ohm???
Sub: Undecided
Amp: Undecided
Wow if your boss sounded the exact same as the 2500 kicker, then tell me the model umber of that boss amp cause i wanna try it. Im not kidding, sometimes these off brands will surprise you, i have an audiobahn amp that hits the same as my audioque 1200d.
its a discontinued class d riot 2500 watt
Sub: Undecided
Amp: Undecided
