Yes Ground to the frame or that will happen cuz the body will not ground it the the car sees it as a short and wont start but if you can get to your frame sand that spot down vert well and even if you need to you can always drill a new hole hope this helps you out
So just finished getting everything put in and hooked up. Everything worked wonderfully. So yesterday I decided to start on my Big 3. I did the Battery to Chassis ground straight from the battery negative, to a bolt on the inside of my fender maybe 3" from the battery. That is the only one I had time to do, so I hopped in the car to leave, and it wouldn't start. It had power, but the starter wouldn't engage. I double and triple checked the terminals and everything was tight. So I took that wire off that I had just run, and the car fired right up. Any ideas?
99 Tahoe
Has New motor and trany has 2 12w6 with 1600watt planet audio amp im looking for the next best thing i want to have a different box so my subs will hit harder along with another amp if anyone has any ideas please let me know im open for new ones
Can u take a pic of what your working with and I can circle the pic and show u good grounding areas
99 Tahoe
sorry bro this sliped my mind
im catching up on all my stuff i have 2 do
i will make a note of this and it will be the first thing in the morning
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
