Sierra07 Posted May 7, 2010 Report Posted May 7, 2010 (edited) Are there going to be VCM's available for newer GM trucks(2007 and up) with the 2 pin alts? Edited May 7, 2010 by Sierra07 Quote
Nathan @ XSpower Posted May 7, 2010 Report Posted May 7, 2010 2 pin oval? The oval 4 wire AD plug will work with 1 wire oval AD plugs. Quote
Sierra07 Posted May 7, 2010 Author Report Posted May 7, 2010 2 pin oval? The oval 4 wire AD plug will work with 1 wire oval AD plugs. The plug receptacle on the alt is smaller than the 4 pin ones, about half the size. Also there are two prongs in it not 4, there isn't any space for more. Quote
Nathan @ XSpower Posted May 7, 2010 Report Posted May 7, 2010 The plug receptacle on the alt is smaller than the 4 pin ones, about half the size. Also there are two prongs in it not 4, there isn't any space for more. Post up a pic and let me see if we have one for that application. Quote
Sierra07 Posted May 14, 2010 Author Report Posted May 14, 2010 (edited) Post up a pic and let me see if we have one for that application. Check out the video on this page from about :40 to 1:10. It shows an alt with the 4pin plug and they proceed to convert it to 2pin. A lot of the newer GM's use this 2pin setup. They started about 5yrs ago. 2pin plug Edited May 14, 2010 by Sierra07 Quote
Nathan @ XSpower Posted May 14, 2010 Report Posted May 14, 2010 No probably not, because most alternators with that plug run through the computer. Quote
