hey guys i have a 5 channel amp with these specs
# 4 ohms: 60 watts x 4 chan. + 475 watts x 1 chan.
# 2 ohms: 120 watts x 4 chan. + 750 watts x 1 chan.
# 1 ohm Mono: 1000 watts x 1 chan. (5th Channel Only)
so i was wondering can i wire my components at 4ohms and my sub on the sub channel at 2 ohms? or is this not possible to do safely? meaning do both either have to be 2 ohm or 4ohm..no mixing?
Shouldn't be a problem
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
ok cause here is what i was going to do, with 475 watts i was gona go with either 1 10 which is rated at 500 watts and put 450 into it or i was going to go with 2 10's and put about 230 watts into each..but if i can get the 750 out of it that will be much better for the 2 10's..im just not to technical on this stuff so i was worried about over heating or clipping..not sure if it would be stable with a combo like that
Just make sure you set your gains accordingly, but you should be fine running chans 1-4 @ 4 ohm and sub chan @ 1-2-4 ohm
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
What kind of amp, what kind of vehicle? Any preferences?
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
its for my brother..im doing early xmas shopping..yes this early..lol
car-2007 cadilac cts
component speakers are 2 sets of Polk Audio db6501
the amp in question is http://www.sonicelectronix.com/item_23827_Hifonics+Zeus+ZXi60.4+%2B+1K.html
the subs i had in mind due to space issues was jl12w3's / kicker 10'' cvx / alpine 10'' type R
I personally go with the Alpines, crutchfield has last years on clearance right now do check it out, I like rockford so check them out as well, a couple p3 10's
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
:werd_msword: I know, just a brand preference for me
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
