Jr217r Posted May 10, 2010 Report Share Posted May 10, 2010 Can some one explain to me what that is... Quote Link to comment Share on other sites More sharing options...
Sanitarium Posted May 10, 2010 Report Share Posted May 10, 2010 it's that box at the top right of the screen that has a button next to it that says search. Quote Link to comment Share on other sites More sharing options...
splzx3 Posted May 10, 2010 Report Share Posted May 10, 2010 i think it needs 2 be bigger people cant see it Quote ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum. Link to comment Share on other sites More sharing options...
Neo_frog Posted May 10, 2010 Report Share Posted May 10, 2010 Passive radiators are used instead of a port for much the same reasons — to tune the small volume and driver for better low frequency performance. Especially in situations in which a port would be inconveniently sized (usually too long for practical box configurations). They are also used to eliminate port turbulence and reduce motion compression caused by high velocity airflow in small ports. The passive radiator usually has some means to adjust its mass also, thereby allowing the user to change the box tuning. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
Jr217r Posted May 10, 2010 Author Report Share Posted May 10, 2010 Passive radiators are used instead of a port for much the same reasons — to tune the small volume and driver for better low frequency performance. Especially in situations in which a port would be inconveniently sized (usually too long for practical box configurations). They are also used to eliminate port turbulence and reduce motion compression caused by high velocity airflow in small ports. The passive radiator usually has some means to adjust its mass also, thereby allowing the user to change the box tuning. Thank you for explaining it to me...now I know what it is Quote Link to comment Share on other sites More sharing options...
