So when ever it comes to needing to do somthing i get an error saying Network Connection problems
i mean help i can't even get onto Itunes store i get a pup up saying
MAke Sure your Network Connection is active and try again now i have know clue how to check and make sure ... lollz
Could be a bad NIC, bad cable, modem/router/switch/hub dieing, or another PC on the network conflicting IP's with you... if your icon on the bottom right is changing between connected and disconnected.
If its not then it could be your ISP is having issues with a recent large update that went out to the "main" internet servers, or your hosts file and/or DNS records are expired... kinda hard to tell without a bit more specific wording.
Hammerdown... 1%
  • 5 weeks later...
Need more info like he said ^^
Team DC Audio : Team Shok : Team NWSPL Co-Founder
Head: Pioneer AVH-P5200DVD
Front Stage: Morel Tempo 6.5's/ CDT 6.5's
Subs: (4) 15'' DC XL's, 15 cubes @ 38hz
Sub Amps: (2) Shok 5k's
Speaker Amp: Shok 100.4
Wiring: Shok Industries 1/0
Electrical: White Mechman 270/Adjustable Voltage/3 Shuriken BT120's/3 XS XP3000's
FPiYT.jpg?9395
