Sampsonite Posted May 15, 2010 Report Share Posted May 15, 2010 quality of parts, design of woofer, and build quality make a sub good or bad. Doubling cone? no, dont do that. A good cone will match to your suspension. Most of the time you want a strong, stiff, rigid yet light cone. Carbon fiber tends to be top of the line. Pressed paper is good too. Lightweight is important. A straight cone is better for SPL whereas a parabolic shape is better for SQ. Suspension parts must be tuned for your cone, coil, and motor. Simply adding spiders is not good. There are various types of spiders made of different materials that have different tensions, stiffnesses, rate of rolls, and sizes. Best to match type and qty to the tension of suspension you want for your motor force and cone and coil weight. Coils are important for power handling and weight. There are a few different type of material. Copper is basic but has good SQ characteristics as well as can be made for good power handling. Aluminum is lighter and great with heat, but raises Fs of a driver. Basically a good design has well balanced parts. Finding that balance can take years of experience and knowledge of materials and woofer engineering. Its the HFI? Is that a 2" coil. You cant really make an entry level sub better without basically building an entirely new woofer. The motor is very small and just adding spiders would reduce efficiency and most likely raise Fs, taking away SQ potential. You can add a taller coil if they exist, but again that would reduce efficiency for the sake of adding 10% more power handling. I say, buy a new motor and a frame that can handle larger spiders and has more clearance for cone travel. Basically, use a different woofer. If you are just experimenting, that good. But that woofer is not a good platform, get a good 3" coil motor to play around with. free expert advise here Quote --Sampson 816-591-6592 www.kcrimshop.com Link to comment Share on other sites More sharing options...
Twistedchild420 Posted May 15, 2010 Report Share Posted May 15, 2010 Love Quote My POS Bass machine-2003 Hyundai Santa Fe on some shitty 22'sBed Liner Paint Job-Pioneer AVH 3200DVD4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)4 Arc Audio XDI2000.1 for the woofers6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters2 Arc Audio KS300.4's for mids and tweets1 Arc Audio ALD 10v Line DriverAll Audiotechnix Power wire1 DC Power 270XP High Output Alternator1 XS Power D3400 up front....6 XS Power D3100's in the rearAir Lift 1000 Bags in rear to help with suspensionIf your still reading this GFY....... Link to comment Share on other sites More sharing options...
