Picked up my car from Mr Singh on Friday who has shown some great skills. The same Mr Singh who won install of the month in the UK :)
So here are some pictures taken during the build and some scores at the bottom which were taken with voltage dropping to 12.4ish new alternator on its way and subs are in process of loosenin' up :)
Box is just under 7 cuft after displacement my estate boot is tiny!!
Took a day to fit reg, alt (inc modifying pulley spacing by 2.5mm) and doing the Big 3 (now defo go down as the very big 3!! :D) Done by dumdum of TalkAudio :)
had to trim the rear corner of the engine cover to make it fit and not chafe the cables
you can just about see the big 3 earth cable on the top bolt hole, can't get much better than bolted to the alts chassis me thinks
over 260 amps at 2krpm, 170ish on idle, not bad for a 210a unit :)
still drops to 13v but with upwards of 300a draw (500-600 max amps) its not doing bad and the diesel doesn't flinch. Will hook up a ctek charger on the batterys soon and get new numbers up :)
Thanks for looking.
Badass. this is a very clean install. Should be plenty loud!!!
Edited by kickin00gpGT
2010 Civic SI sedan: Crystal Black Pearl
All stock.
Looks really good in their. Pics of full car?
2000 Blazer 4dr
-24" Boss 330s
-Lowered 2/3
-5000k Hids w Projector Retro
-Candy tails
-LED interior lighting
-20% tint 35% windshield
-Alpine 9886 HU
-RF P1462 Dash
-RF P1652 Front
-RF P1652 Rear
-Two 18" Fi BTLs
-MB Quart Onyx 4.80
-Two Audioque AQ2200Ds
-Xs Powerr D5100, 2 Powersafe G31s
-Knukoncepts 1/0 wire
-Mechman 270 Alt w Boost Module
-10.4 Net @ 28hz 140sq.inch of port
My Youtube Channel!!
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
