Guest Posted May 19, 2010 Report Share Posted May 19, 2010 why not just run your low beams on all the time? Quote Link to comment Share on other sites More sharing options...
alan412 Posted May 19, 2010 Report Share Posted May 19, 2010 can you take out the bulbs? that would solve your problem Quote (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
Robert8252 Posted May 19, 2010 Report Share Posted May 19, 2010 Did you actually look in your engine compartment. I know for a fact with early 2000 fords it was simply a DRL fuse in the engine compartment usually around the battery depending on vehicle. It wasn't untill 04 that ford started making DRLs into the computer programming Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff Link to comment Share on other sites More sharing options...
BeatBox Posted May 19, 2010 Author Report Share Posted May 19, 2010 why not just run your low beams on all the time? well my mom uses the van and she wont remember to turn on the headlights before shifting....if i was the only driving it shit i would mind it. Did you actually look in your engine compartment. I know for a fact with early 2000 fords it was simply a DRL fuse in the engine compartment usually around the battery depending on vehicle. It wasn't untill 04 that ford started making DRLs into the computer programming yes sir checked rear the owners manual, the fuse i mentioned before was under the dash. theres two fuse boxes. and this van is the fancy SPORT editon with the sweet spoiler, has turn signals in the mirrors too. Quote Link to comment Share on other sites More sharing options...
alan412 Posted May 19, 2010 Report Share Posted May 19, 2010 can't you just take out the day time running light bulbs? Quote (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
BeatBox Posted May 20, 2010 Author Report Share Posted May 20, 2010 no its a single 9007 bulb the HID's is just the low kind too, not he high/low HID kind. but that wouldnt matter any ways damn day time running lights will still kick on Quote Link to comment Share on other sites More sharing options...
alan412 Posted May 20, 2010 Report Share Posted May 20, 2010 no its a single 9007 bulb the HID's is just the low kind too, not he high/low HID kind. but that wouldnt matter any ways damn day time running lights will still kick on oh i see. that really sucks. good luck with finding a solution Quote (Headunit) Pioneer DEH-P3100UB (Speakers) Phoenix Gold RSd 65cs (4 Channel) Alpine MRP-F300 (Subs) 2 15" Audioque SDC2.5 (Box) 7.27 cubic feet tuned to 31 Hz (Mono Amplifier) Elemental Designs Nine.1 (Wiring) 1/0 Knukonceptz KLMX (Batteries) 2 C&D Tech 75 a/h Link to comment Share on other sites More sharing options...
JCiarlino Posted May 20, 2010 Report Share Posted May 20, 2010 Kinda hard to explain but I'm gonna try anyway. Take your headlight switch out, find out what wire turns the headlights on and disconnect that from the switch. Run that wire to a circuit in your fuse panel that only has power when the key is in the run position. So that way whenever the key is run, the headlights will be on. I did that with my car so I could have auto headlights. Quote Link to comment Share on other sites More sharing options...
BeatBox Posted May 20, 2010 Author Report Share Posted May 20, 2010 oh i see. that really sucks. good luck with finding a solution thanks for trying to help! i hope i find a solution too! Kinda hard to explain but I'm gonna try anyway. Take your headlight switch out, find out what wire turns the headlights on and disconnect that from the switch. Run that wire to a circuit in your fuse panel that only has power when the key is in the run position. So that way whenever the key is run, the headlights will be on. I did that with my car so I could have auto headlights. yeah could try that too....now to find that wire. it shouldnt be hard tho Quote Link to comment Share on other sites More sharing options...
JCiarlino Posted May 20, 2010 Report Share Posted May 20, 2010 If I still lived on campus I could run up to my school's library, jump on one of the computers with Mitchell or AllData and tell you exactly what wire it is. Quote Link to comment Share on other sites More sharing options...
