building a clamshell
Bolts or screws, and I am planning on a clamshell also, what's your tuning or are you goin sealed?
dc lvl 4xl 12
kicker zx1500
2 sets of kicker ds6.5s
optima yellow top (extra batt) with big 3
1/0 guage and 3 150amp anls
eclipse cd5000 headunit
4th word of his post
id use bolts to mount it to the vehicle.
as for the 2x4 thing, ive seen it done before. the outside is all 2x4 with a layer or two of mdf for the inside.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Oh and as far as the frame goes you can do 2X4s and make a box to slide in so you can do most of the work outside of the van and then just screw to the frame and seal off the edge from there
dc lvl 4xl 12
kicker zx1500
i wanted to use the 2x4s as the box and just have the baffles be mdf. this way the cube will always be the same just different faces of sort.
ive seen most put mdf over the 2x4s but i was wondering if its really necessary if i put fiberglass over to make it smooth.
i will most likely be going sealed due to not knowing how to calculate a port. i usually use the internet for boxes this is my first really big build
  • Who's Online   1 Member, 0 Anonymous, 1217 Guests (See full list)
