i was thinking about building a tline box for my little tang band 8"
but even after reading into them a little, im still lost as to how to build one
was wondering if i could get some help with designing one
here are the specs for the sub
Tang Band W8-670Q
any help would be appreciated
Posted (edited)
Read...
seriously...
the first post will explain everything...
read it a few times over...
fs of the woofer is 38hz... 1130/38 = 29.736 /4 = 7.434 * 12 = 89.21 inches... thats how long the port has to be...
sd = .022 m = 34.1000682 inches sq...
34 sq inches of port 89.21 inches long...
took me less then 5 mins to calculate...
the trickest part is to make the port exactly 89.2 inch long...
easiest way to build a tline is with a pvc pipe... get one 8in in diameter, make it 89.21 inches long... mount it on one end..
edit: you dont have to be too exact... round to the nearest quarter inch
Edited by spl4life
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
i know you already posted some specs but after reading that thread a few times i got these as my numbers:
7.43 ft (same as what you got)
but when i measured the cone to get the surface area, i got 7.25 from middle of surround to the middle of surround. and if i do the same math as he did then it should be 7.25/2 then 3.63*3.63*3.14 = 41.38 which would round down to 40sq in
am i right so far?
but the main thing im lost on is how to design this, its gonna be for my truck btw, so i was gonna do mdf not pvc pipe.
incase someone wants to help my MAX dimensions are:
Width: 53"
Length: 34"
Height: 21"
but i would prefer the width to be either at or under 35" cuz i still wanmna use my back seat
i was gonna ask a buddy of mine about helping me design today, but idk how much he knows about T-Lines, so again any help is appreciated
ygpm
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
