if your alternator can handle 2 batteries, get 2 batteries. Normally a few runs of 1/0 from the front to the back does the trick, but with a set up like that I would look into high output alternators before anything else.
replace the stock battery
(Headunit) Pioneer DEH-P3100UB
(Speakers) Phoenix Gold RSd 65cs
(4 Channel) Alpine MRP-F300
(Subs) 2 15" Audioque SDC2.5
(Box) 7.27 cubic feet tuned to 31 Hz
(Mono Amplifier) Elemental Designs Nine.1
(Wiring) 1/0 Knukonceptz KLMX
(Batteries) 2 C&D Tech 75 a/h
yes. run the pos to pos for each batt. then ground the batts in the back or do a run of neg to neg as well.
a single HC800 is not gonna do the trick for that.
what i meant by that was replace the stock battery as well as adding the batteries in the back. and ofcourse a h/o alt would do the trick
how big of an alternator? cuz ive been looking and the biggest ive found for my car is a 205a alternator
I'm pretty sure tylertron just installed a 320 amp alt from iraggi in his alero...
replace the stock battery... mixing batterys are not a good idea... if you do your kinetics will average out with the stock battery voltage...
id grab another 1800 and put it up front...
edit: HO alt is a must... check out dc power..
Edited by spl4life
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
if the 04+ fits onto my 01 alero then i ahve a 300a alt but if not highest ive found was 200a
so 3 1800 and a big three upgrade?
  • Who's Online   0 Members, 0 Anonymous, 1223 Guests (See full list)
