SICKSPD Posted May 29, 2010 Report Posted May 29, 2010 Im looking to buy one of these two amps to power 4 8" DD 1500 series subs. From what i can see on there specs they are pretty much the same. their wattage rating is the same at every ohm load. Can anyone tell me which is better or atleast what is different about them? or is one an older model than the other? thx They are: Planet Audio RXD2400 and Planet Audio AP3000D btw I looked over the specs again and the classes are different ones D and the other is A/B, can someone explain what that is please? also the max gauge input is different. 09 Challenger R/T (Audio system under construction): Pioneer AVH-X4500BT (PAC RP4CH11 harness) (2) Sundown Audio SA-8v2 (inverted) CT Sounds AT1400.1D XS Power D3400 40 sq ft. Audiotechnix deadener 1/0 Audiotechnix wiring stock Boston Acoustic 7 speaker amplified system (for now) Sealed trunk enclosure Build log: http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/ TEAM GOAT
