Mosfet power supply
High current bi-polar output design
Audiophile grade NE5532 OPAMPS
12dB/Oct. Crossover
Variable high pass (50Hz-500Hz & 500Hz-5KHz)
Variable low pass (50Hz-500Hz & 500Hz-5KHz).
Bandpass crossover on 450.4
Variable bass EQ 0dB - 12dB @ 45Hz
5 -way protection circuit
Through output for running multiple amplifers
Soft start / mute circuit
2Ohm Stereo / 4Ohm mono operation
Channels: 4 CH
Rated Power: 14.4 VDC
4-Ohms: 1 x 200 watts RMS
2-Ohms: 1 x 400 watts RMS
1-Ohms: 1 x 600 watts RMS
Frequency Response: 10Hz ~ 30Khz +/- 0.5dB
THD + Noise: <.1%
S/N Ratio: > 100 dB
Input Sensitivity: 150mV ~ 5.0V RMS
Fuse requirement: 8O amps
Dimensions (LxWxH): 13.0 x 8.5 x 2.25"
This might come in handy if you have any questions, http://www.imagedynamicsusa.com/pdf/iD%20Product%20Spec's/Manual%20Q-amp.pdf But I'll answer any also.
These go new for $550..
NEW PRICES, $180 each, or $320 for both. THESE AMPS ARE TRUE 600 WATTS RMS.
Edited by TLEJ
This topic is now closed to further replies.
