I have a '96 'Prix and on mine, right by the steering column there is a riveted-in different type of metal that had nothing on either side; that's where I drilled my hole. Your mileage may vary, but I would check there. Just don't do what I did and put it in the middle of the pedal box; I got a nice swell in the carpet right by my foot now from my 1/0 lol. Go more towards the driver's side of the firewall or something.
Too many projects, too little time...
And depending on how thick the wire is you could always run the wire under your trim panels.
just to be nosey where on the firewall of your jeep did ya drill your hole? right now i drilled a hole on the passerger side floor and ran it threw
Team DBs (Driven By sound)
I did it in the exact same spot, passenger side floor board. Comes out a preexisting hole in wheel well, zipped tied it up and ran it through the battery.
I have tried to stick a few things through the firewall and no luck, it seems like theres metal between the engine and the interior, is the firewall just made out of some plastic that i need to drill thru?
that would be the Firewall.lol
d(-__-)b
wonder if the 96 still has that spot. i just went under the firewall threw the hole i drilled and ran it to the back. but if your way is better i'll change it.
Yeah not real easy cuz you drill through the floor pan, then reach through the hole in the wheel well and you can feel the wire. Pull it through and then there was a small rust spot that was rust through just a lil bit so i drilled it out and popped in a rubber grommet. I have a 1993 as you can see in the sig.
ok its kinda really dark out right now lol and the rain just made me stop for the night, i think im going to drill my hole right under my glove box and see if that will work, i hate havin short wires to work with :(
To buy list: 1x AQ HDC315 Copper Coil sub, 1x AQ1200D amp, Wood for sub box, Wiring, Car Alarm, Time and MONEY!
  • Who's Online   1 Member, 0 Anonymous, 1415 Guests (See full list)
