i am running 2 mtx 8515-44 wired to 2 ohm . i build the recimendated box size for them of 2 cubic feet per sub . question is should i have gone bigger ? the amps running them will either be fosgate power t500bdCP or t1000bdCP . one amp per sub.
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
if your running sealed I'd stick to specs. I'd be different if you were porting them
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
would they hit harder if i went with a ported box ?
Yes it all depends on what your going for. Sound Quality or SPL.
for this ride sound quality. is sealed better for that ?
generally yes but it depends on the car and the box. its alot of trial and error with a ported box but you can get good sound quality out of a ported box. If you have no experience with ported stick with sealed. Down the road you can always try to build a ported box once you have more knowledge on how they work
well i did build a ported box back when i 1st got the sub . its a big box at 2.50 cube feet. sounded great . just not enought room to build a ported box for 2 15's .
sealed would be the way to go if you're limited on space
sweet i made the right choice. now comes the question do i need to beef up the box and fiber glass it then body filer to make it stronger ? ive watch the you tube videos and steve does it to all his boxes
  • Who's Online   0 Members, 0 Anonymous, 1910 Guests (See full list)
